Use the Specifications tool to assign a weld
specification.
Note: In cases where there are a large number of welds in the model, it may be better to
specify the classification after completion of the screening process so that the
classification parameters can be specified only for the welds that need to be
evaluated.
Click the Specifications tool.
The Weld Specification dialog opens.
Select an option from the regulation drop down menu.
Click Apply.
Default parameters are applied to all weld line
evaluation points according to the selected specification.
