Change the Entity View in the Results Browser
Quickly display all entities of a specific type in the Results Browser.
View new features for HyperLife 2023.
A comprehensive fatigue solutions framework.
Explore the user interface.
The ribbon allows you to quickly access tools and standard functions, and is located along the top of the user interface. Click on an icon to open the related tool. Hovering over a group of icons may reveal additional tools.
The Results Browser allows you to view the model structure while providing find, display, and editing control of entities.
Expand and collapse folders to better view model hierarchy.
Sort the entities within a folder.
The Results Browser contains several ways to filter results data to display specific entities in the browser.
The Local Display Controls affect the visual style of individual entities (such as shaded or wireframe).
Change the entity types, columns, options, and toolbars that are displayed in the Results Browser.
The Model Info dialog displays general information and statistics about your model.
Use the Entity Editor section of the Results Browser to view and edit various entity conditions/properties.
The modeling window is where your model is displayed.
The status bar displays information pertaining to the currently loaded model.
Use the toolbelt to quickly access frequently used tools.
Context menus are floating menus that are accessed by right-clicking on elements in the user interface. They provides immediate access to a short list of commands that are contextually relevant to the selection.
The Tcl Console enables you to enter and execute Tcl/Tk commands instead of using the user interface.
The Message Log lists the actions performed in the current session. The dialog also provides you with information about your file (warnings, errors, and so on).
Certain parts of the user interface, such as browsers, toolbars, and panels, can be undocked and repositioned as needed.
View controls enable you to control the view and display of your model in the modeling window.
Select and deselect entities to modify with other tools. Selected entities are outlined to indicate their selection state.
Adjust HyperLife settings.
Discover HyperLife functionality with interactive tutorials.
Fatigue Analysis is intended for solutions to structures in a large number of loading cycles.
Set up your model for analysis.
Run the model and view results.
Explore additional post-processing options related to the input result files.
ON THIS PAGE
ON THIS PAGE
