Click the Load Map tool.
The Load Map dialog opens.
From the Channel Type drop-down menu at the top of the dialog, select
Input PSD: Real & Imaginary.
Load PSD vs Frequency data (input PSD that is to scale the FRF stresses).
Click
in the Choose File
field and browse for psd_X.csv,
psd_Y.csv, and
psd_Z.csv.
Click
to add the load case.
- Optional:
Click
to view a plot of the loads.
Select Subcase 1 (Load_X), Subcase 2
(Load_Y), and Subcase 3 (Load_Z).
On the bottom half of the dialog, click
to create an Event_1
header.
The possible correlations of Subcase 1, Subcase 2, and Subcase 3 are
listed under the event.
Select the three psd files and drag-and-drop them into the
Event header.
Note: Any blank correlations are not considered in the calculation.
The following pairs are created:
The remaining correlations are left blank.
Activate the Event_1 checkbox.
Set the Exposure Time for the event to 18000.
Exit the dialog.
Note: If Mean Stress correction is to be applied, a static subcase, if present in the
result file, will be listed in the Subcase window and can be drag and dropped onto
the event (no channel is required to be paired).
