HL-T: 1030 Multiaxial Strain-Life (E-N)
In this tutorial you will:
- Import a model to HyperLife
- Select the EN module and define its required parameters
- Create and assign materials
- Assign load histories for scaling the stresses from FEA subcases
- Evaluate and view results
Import the Model
From the Load model and result dialog, browse and select
HL-1030\Ibeam.h3d for the model
file.
The Load Result field is automatically populated. For this tutorial, the same file is used for both the model and the result.
Click Apply.
Tip: Quickly import the model by dragging and
dropping the .h3d file from
a windows browser into the HyperLife
modeling window.
Define the Fatigue Module
Click the arrow next to the fatigue module icon and select the
EN tool from the list of options.
Figure 3.The EN dialog opens.
Define the EN configuration parameters.
- Select Multi Axial as the method.
- Select MPa for the FE model units.
- Enter a value of 20 for the number of planes.
- Enter a value of 0.5 for the certainty of survival.
- Select SWT for the tension damage model.
- Select FS for the shear damage model.
- Select Worst for the layer selection.
- Select Time Series for the type of loading.
Figure 4. - Exit the dialog.
Assign Materials
Click the Material tool.
Figure 5.The Assign Material dialog opens.
- Activate the checkboxes next to the parts Flange and Web.
Create a new material.
- Click the My Material tab.
Click
to create a new material.
- Name the material Mat_EN_multiaxial.
- Set the Elastic modulus to 70000.
- Set Poisson's ratio to 0.334.
- In the EN tab, set the Standard Error of Log(elastic strain) (SEe) to 0.1.
- Set the Standard Error of Log(plastic strain)(SEp) to 0.1.
Accept all other default settings, both in the EN and Other tabs, then
click Plot & Save.
Figure 6.
- Right-click on Mat_EN_multiaxial and select Add to Assign Material List.
Return to the Assign Material Data tab and select
Mat_EN_multiaxial from the Material drop-down menu
for both Flange and Web.
The Material list is populated with the materials selected from Material Database and My Material.Figure 7.
- Exit the dialog.
Assign Load Histories
Click the Load Map tool.
Figure 8.The Load Map dialog opens.
- From the Channel Type drop-down menu at the top of the dialog, select Time Data.
Click
in the Choose File field and browse for load1.csv.
Click
to add the load case.
- Repeat steps 3 and 4 for load2.csv, load3.csv, and load4.csv.
- Optional:
Click
to view a plot of the loads.
Figure 9. Load 1Figure 10. Load 2Figure 11. Load 3Figure 12. Load 4Tip: Expand the width of the dialog to view a clearer picture of the plot. - On the bottom half of the dialog, set the radio button to Auto for event creation.
Select both the load 1 (block1) and load 2
(block1) channels and Subcase 1 and
Subcase 2, then click
to create the first event.
- In a similar manner, create a second event by selecting load 3 (block1), and load 4 (block1), Subcase 1, and Subcase 2.
- Activate the checkboxes for the two events.
Set the Scale as shown in the image below.
Figure 13.
- Exit the dialog.
Evaluate and View Results
From the Evaluate tool group, click the
Run Analysis tool.
Figure 14.The Evaluate dialog opens.Figure 15.
- Optional: Enter a name for the run.
Click Run.
Result files are saved to the home directory and the Run Status dialog opens.
- Once the run is complete, click View Current Results.
Use the Results Explorer to
visualize various types of results.
The contour below highlights the total damage (Event 1 + Event 2).Figure 16.Figure 17. Event 1: Damage matrix for element 18802Figure 18. Event 2: Damage matrix for element 18802
