The averaging options allow you to limit the averaging of results to only a group of elements that are considered to be
bound by same feature angle or face.
Use the Vector tool to set options for a vector plot.
Individual vector components, shear, and complete resultants
can be plotted for vector based results.
Attention: The Envelope utility is not intended for use with vector plots. If
it is used with a vector plot, HyperLife will simply draw the
last loadstep in the derived loadstep list.
