In order to import sets in any format, you must first load
a model.Note: You can import more than one of these files into the same session.
Click the Sets tool.
From the Set panel, click Import.
The Import Sets dialog is displayed.
Select a file type (HyperView set definition file,
Animator3 session file, LSPost set file, Patran session file, or Nastran/OptiStruct set file)
from the Select format drop-down menu.
Under File name, click the open folder icon and browse to the desired file
which contains defined sets/groups.
Click Open.
Click OK in the Import Sets dialog.
