The list of available operators is controlled by the template file selected when loading a model and result, and it can
be modified by adding or removing <using /> statements in the template.
Additional resources can be attached to the analysis for the purpose of adding new
tables.
For example, if an external file contains material yield
tables, they can be loaded by selecting the file. External resources that are added for result
math purposes are available as file parameters for report templates. Any constants file or
additional result files added as a resource in baseline iteration can be interchanged or
updated when applying a report template for subsequent iterations.
