If the Notes
panel is not currently active, right-click on a note in the Results Browser and select Edit.
To attach a note to an entity:
From the Notes panel, select a note in the Notes list.
Under Attach to, select Entity.
Select an entity from the input collector menu.
Select the entity.
Click Apply.
The note is attached to the selected entity.
