Add a Measure Group Do one of the following: From the Home tools, click the Measure tool. Figure 1. Then, from the Measure panel, click Add under the Measure Groups list. Right-click in the Results Browser and select Create > Measure. A new measure group with a default name is added to the list.Tip: Use the Rename (right-click context menu) option to rename the new measure group if desired.
