HyperMesh
When possible, HyperMesh CFD checks strive to maintain compatibility with popular solvers.
2D and 3D Element Checks
- Aspect Ratio
- Ratio of the longest edge of an element to either its shortest edge or the shortest distance from a corner node to the opposing edge ("minimal normalized height"). HyperMesh CFD uses the same method used for the Length (min) check.
- Chordal Deviation
- Largest distance between the centers of element edges and the associated surface.
- Interior Angles
- Maximum and minimum interior angles are evaluated independently for triangles and quadrilaterals.
- Jacobian
- Deviation of an element from its ideal or "perfect" shape, such as a triangle’s deviation from equilateral.
- Length (min)
- Minimum element lengths are calculated using one of two methods.
- The shortest edge of the element. This method is used for non-tetrahedral 3D elements.
- The shortest distance from a corner node to its opposing edge (or face, in the case of tetra elements); referred to as "minimal normalized height".
Figure 2. Length CheckNote: This setting affects the calculation of the Aspect Ratio check. - Minimum Length / Size
- Minimum element size is calculated using:
- Shortest edge
- Length of the shortest edge of each element is used.
- Minimal normalized height
- Is a more accurate, but more complex height.
- Minimal height
- The same as minimal normalized height, but without a scaling factor.
- Skew
- Skew of triangular elements is calculated by finding the minimum angle
between the vector from each node to the opposing mid-side, and the
vector between the two adjacent mid-sides at each node of the
element.Figure 5. Skew of Triangular ElementsNote: Skew for quads is part of the HyperMesh-Alt quality check.
- Taper
- Taper ratio for the quadrilateral element is defined by first finding
the area of the triangle formed at each corner grid point.Figure 6. Taper for Quadrilateral Element
- Warpage
- Amount by which an element, or in the case of solid elements, an element face, deviates from being planar. Since three points define a plane, this check only applies to quads. The quad is divided into two trias along its diagonal, and the angle between the trias’ normals is measured.
3D Element Only Checks
- Two methods are used to calculate the minimum element size.
- Shortest edge
- More accurate, but more complex.
- Tetra Collapse
- The height of the tetra element is measured from each of the four nodes
to its opposite face, and then divided by the square root of the face’s
area.Figure 9.
- Vol. Aspect Ratio
- Tetrahedral elements are evaluated by finding the longest edge length and dividing it by the shortest height (measured from a node to its opposing face). Other 3D elements, such as hex elements, are evaluated based on the ratio of their longest edge to their shortest edge.
- Volume Skew
- Only applicable to tetrahedral elements; all others are assigned values of zero. Volume Skew is defined as 1-shape factor, so a skew of 0 is perfect and a skew of 1 is the worst possible value.
