General Measurements
Measure length, angles, radii, volumes, areas, bounding boxes, and more.
Measure Length, Angles, and Radii
Use the Measure tool to draw, length, angle, and radius measurements in the modeling window.
- Use snap points to draw lines that are perpendicular or tangent to other lines, and snap to predefined points on your model such as end, middle, center, and intersection points.
- Use the dimensioning option to modify distance, components, and angle values for selected nodes or points. These values can be in reference to a local system.
Calculate Summary Measurements
Use the Query tool to measure areas, volumes, entity counts, line lengths, bounding boxes, and more.
