<donor_position_factor>
This factor is applied to a reference length (see
below) to determine the exact distance to the wall
where the wall model is extracting information from
the flow. The default value of 3.5 together with the
default reference length corresponding to the near
wall voxel size leads to a setup where the donor
position is placed in the third layer of voxels
above the wall.
<donor_position_use_local_reference_length>
The reference length is coupled to the voxel size at
the wall. This parameter controls if a local
reference length per refinement level or a global
reference length is used.
If set to true (default), the reference length is
evaluated per refinement level, which moves the
donor position closer to the wall in regions of
finer grid.
If set to false, in case the wall touches voxels of
different refinement levels, the coarsest voxel size
at the wall will be used as a reference length, also
in regions of finer grid.
