Dye Regions
Used for fluid motion tracking.
- Dye regions can only be spherical in shape.
- If a particle passes through multiple dye regions, it will adopt the color of the last dye region through which it passed.
Commands
dyeRegions
dyeRegion
dyeregion_clr 1
dyeregion_cntr "0.0 0.1 0.2"
dyeregion_rad 0.1
dyeregion_radodx 2.5
dyeregion_tstart 0.0
dyeregion_tend 1.0
Command | Contents | SI Unit Example |
dyeregion_clr | Color assigned to the dye region | |
dyeregion_cntr | Center coordinates of the dye region sphere | [m] |
dyeregion_rad | Radius of the dye region sphere | [m] |
dyeregion_radodx | Radius of the dye region sphere as a function of
dxdx
Tip: For example, when
specified 3.0, this implies
3.0*dx3.0*dx
Note: If both
dyeregion_rad and
dyeregion_radodx are present, the latter
takes precedence.
dyeregion_tstart | Start time of dye injection | [s] |
dyeregion_tend | End time of dye injection | [s] |
