PRINT Command
The PRINT command prints strings, numbers and other information to screen or the .out file to display the solution progress and for debugging purposes.
- Prints text to screen.
- !!print_warning
- Prints the warning messages to the screen.
- For terminal runs, the string “WARNING” precedes the warning message.
- For runs from the GUI, the warning message is displayed in colour.
- !!print_error
- Prints the warning messages to the screen. To stop execution use the !!EXIT statement.
- !!print_to_out
- Writes the text to the .out file while the Feko kernel is run.
The print commands accept multiple arguments separated by commas.
Example 1
!!print "2*#b = ", 2*#b
!!if #a < 2*#b then
!! print_error "The value of #a is too small:", #a, " (exiting now)"
!! exit
!!endifExample 2
Print the value of #b to the .out file at the location where it appears in the .pre file.!!print_to_out "This run was done with #b = ", #b
