Suspect Items
An item is marked suspect when changes in the model result in the settings of an item becoming unresolved or invalid.
Figure 1. An example of a suspect item and its tooltip in the model tree.
- If a lossy conducting surface is set on a face bordered by free space and one of the bordering regions is set to PEC, the unsupported lossy conducting surface is removed. The face is marked “suspect” and its medium displayed as PEC in the details tree.
- If a port becomes invalid due to a change in the model, the port is marked “suspect”.
