Quick Tour of the Component Library
The component library consists of two main panels.
Figure 1. The Component library dialog. On the left, the first panel for browsing components and to the right, the second panel for refining the component.
- Components
View the list of components (antennas and platforms) in the component library. Find a component quickly by either entering filter text or filter the list according to the component type. To select a component, click on an item in the list.
- Geometry preview / results
View images of the selected component in 1. Click on an image to maximise and click again to minimise.
- Antenna settings
- Refine the selected antenna with additional options and settings.
- Click the
icon to view the
solution methods in the Feko
documentation.
- Solver information
- View a summary of the solution methods that can be selected to solve the antenna. Not all solution methods are supported for each component due to differences in how the component model is set up.
