Cable Schematic Display Options
View the display options for the cable schematic view.
| Icon | Name | Description |
| Rotate | Rotate the selected item. | |
| Cross sections | Show / Hide the cable-cross section display. | |
| Connector spacing | Set the spacing factor between connectors on the cable schematic view. | |
| Projection | Projection on the XY plane. | |
| Projection | Projection on the XZ plane. | |
| Projection | Projection on the YZ plane. |
