Legend Range Settings
Adjust the legend range for the current active surface graph.
Cartesian surface graph data can be clamped between two values to help reveal changes in a result that would be missed with the default range. The colouring of the result is changed whereby blue corresponds to the minimum value and red to the maximum value.
Figure 1. The Legend range settings dialog.
The following settings are available:
- Round off legend range and step size
- Data is often represented in a decimal form to represent a value accurately. The
number of digits after the decimal point could result in a legend range that is
difficult to read and interpret.
Select this option for a more legible legend containing rounded off values. The original data range is contained within the rounded off range.
