The Application Default Settings
Application Default settings allow you to specify global (i.e., application-level) work settings for Monarch Data Prep Studio.
Import
The Import tab allows you to specify how files should be imported into Data Prep Studio.
GENERAL
- Default source row limit
If necessary, you can specify a row limit to enable partial data loading of excessively large files and improve the application's performance. To do so, use the dropdown provided and select Limit: from the options that display. In the field that appears to the right of this selection, specify a row limit to apply when opening tables.
Note that the number of rows displayed does not affect the number of rows obtained when a table is exported. You could, for example, set a limit of 10,000 rows to view when opening a table with 1,000,000 rows. When ready, you may opt to export only 10,000 rows or all 1,000,000 rows as necessary.
Note also that the application imposes a 2,000-record limit when opening SalesForce reports. To get a full view of the data when opening SalesForce reports with over 2,000 rows, export the data to a CSV file in SalesForce and then use the Text plugin to import the data.
Automatically sync columns with source data on load or refresh data for supported data sources
Tick this box if the columns in your file change over time and you require that Monarch Data Prep Studio sync with these changes. While in this mode, your Change History items may reflect errors if the column they were applied to is renamed or deleted from the source file. The supported data types for this mode are delimited text and Excel.
- Default Excel Importer
You can select a default Excel importer to use when one has not been explicitly chosen (e.g., an Excel file is dropped into the application, the Open File or Open Web File buttons are selected in the Open Data dialog).
- Prompt for choice
- Open as a Database
- Open in Worksheet Design
- Default PDF Importer
You can select a default PDF importer to use when one has not been explicitly chosen (e.g., when a PDF file is dropped into the application or when the Open File or Open Web File buttons are selected in the Open Data dialog).
- Prompt for choice
- Open in Report Design
- Open in PDF Table Extractor
Apply to current Workspace
Tick this box if you wish to apply the settings in this tab to the current workspace.
EXCEL
These settings allow you to specify options when importing new data from Excel.
Excel Import Connector
Select whether to import new Excel data using the Monarch Excel Table connector (i.e., the Aspose engine) or the ACE OLE DB connector (i.e., the legacy engine).
Upgrade settings for existing workspaces
When an existing workspace containing an existing Excel data source is opened, select whether to retain the use of the original import connector to load the data or use the Monarch Excel Table connector instead.
Default sample size when detecting Excel column types
The sample file size specifies how Monarch Data Prep Studio determines the data type of a column coming from Excel.
Take the following example:
Column A
Row 1 1234
Row 2 4569
Row 3 4568
Row 4 4562
Row 5 4562A
If the default sample size is set to 4, Monarch Data Prep Studio will scan up to Row 4 and the column datatype will be Numeric. When the table is displayed, Row 5 will be NULL. If the default sample size is set to 5, Monarch Data Prep Studio will scan up to Row 5 and the column datatype will be Text. All values from Rows 1-5 are displayed.
Select a sample size that ensures Monarch Data Prep Studio can make a correct assessment of the data type. At the same time, be mindful that if you select a very large sample size, you sacrifice speed in loading data.
Show Excel named ranges when opening an Excel workbook
Check to import Excel named ranges as individual tables. When you load an Excel source containing multiple sheets and sheets with named ranges, each sheet and named range will be listed as individual tables in the Preview window.
Named ranges will be visible only to Excel workbooks you open after this setting is enabled, including Excel files added to the Prepare window via drag and drop.
This setting is not affected by the “Apply to current workspace” or the “Apply to recent data sources” checkboxes.
Import all columns as text to avoid potential loss of data during type conversion
Check to convert all columns imported from the data source as text regardless of their original type. Note that toggling this checkbox in Application Default Settings will not affect the column types in existing load plans.
WORKSHEET DESIGN
Utilize unformatted values from Excel for numeric and date columns
Tick this box if you wish that Excel Worksheet Design use unformatted values from Excel cells for various operations, including cell/column type detection, "Is Number" and "Is Date" value rule behaviors, and the output table values for numeric and date columns.
- Recursively evaluate formulas
When this setting is enabled, if a worksheet's cells depend on the cells of other worksheets, the dependent cells in these other worksheets will also be calculated. Note, however, that this setting may have an important impact on the application's performance, particularly if numerous cells must be calculated.
Rows to scan for columns
In the box provided, indicate a number of rows that must be scanned by Monarch Data Prep Studio to determine what data type to assign to a certain column. Note that setting this number to a very high value may negatively impact the application's load performance depending on the number of rows and columns in your input source.
The following settings allow you to specify options when importing new data from Report files. These settings are also made available to you when you click Report Design Settings > Input in the Report Design window.
Setting |
Description |
Security |
Automatically redact sample text |
Use this option to automatically redact the sample text line in Report Design. |
Formatting |
Encoding |
Use this setting to specify the default report file format. The following encodings are supported by Monarch Data Prep Studio:
These options may also be accessed in open files by right-clicking on the report in Report view. |
Code page |
Select the appropriate code page to use with the chosen input file encoding format. This option is only applicable to the ASCII (14 codepages available), ANSI (10 codepages available), and EBCDIC (16 codepages available) encoding systems. These options may also be accessed in open files by right-clicking on the report in Report view. |
File Type |
This option is enabled only when EBCDIC is selected as the encoding type. Choose from one of the following options:
Ignore print control characters |
Select this setting to have Monarch Data Prep Studio ignore all print control characters below ASCII 32 except for:
Ignore additional non-printing and control characters |
A number of Unicode characters are known to cause misalignment issues with Report Design's character position-based data capture. These characters include U+008D (reverse line feed), U0080 (padding character), U+200B (zero-width space), and U+FEFF (zero-width no-break space), for example. Select this box to ignore these characters. |
Hide n leading characters on each line |
When you download print files from a network, a mini-computer, or a mainframe, one or more extra characters may appear at the beginning of each line. The exact number and type of characters depends on the operating system. These introductory characters are typically used for form feed, carriage return, or line feed printer commands. They are usually not needed in a PC file and may affect the way the file is displayed by Monarch Data Prep Studio. A few communications programs are smart enough to either discard unnecessary characters or translate useful characters into the corresponding PC character codes. However, a form feed command is typically the only useful character you may get, and most communications programs are unable to translate it. Use this setting to specify the number of leading characters to strip from each line of the report. Typical values are 0, 1, and 2. The value can be in the range 0 - 99. For example, if you download from an IBM 3090 mainframe computer using an IRMA communications card, each line in the report will be preceded by two non-productive characters. You can strip those characters from the data by entering 2 in the Hide leading characters box. |
Page Break |
Ignore the form feed character |
Selecting this setting causes Monarch Data Prep Studio to ignore all form feed (page break) characters in a report. Use this setting to turn off the hard-coded page breaks in a report file and replace them with page breaks based upon a Page Header trap or based upon the ForcePageBreakAfter n Lines setting (see below). |
Page break on hidden leading text: n |
For some mainframe and midrange system generated reports, especially from AS/400 systems, a page break could be indicated by a leading control character in the report file. This option allows you to hide the control character and to force a page break when a specified character is encountered. Note: This option is not accessible unless you specify a Hide n Leading Characters setting. |
Force page break after n lines |
Use this setting to add page breaks to a file at regular intervals by specifying the number of lines you want on each page. Monarch Data Prep Studio scans the report for existing page breaks and inserts a virtual page break whenever a real page break has not been encountered before the number of lines specified. |
Fields |
Trim leading and trailing spaces from Character and Memo fields |
This setting instructs the application to remove all leading and trailing spaces from character and memo fields. |
Trap Characters |
Trap characters |
This setting allows you to specify whether you want to use Monarch Complete's standard trap characters or the alternate ones. The Alternate trap characters have been chosen to be compatible with different languages, so that characters that are commonly used in a language are not chosen as wildcard trap characters. For example, in the standard trap character set, the Alpha Trap uses a character which is common in Portuguese, the Numeric Trap uses a character which is common in Spanish, the Blank trap uses a character which is common in German, and the non-blank trap uses a character that is common in Scandinavian languages.
Note: The characters used in the Alternate trap set are all low ANSI, i.e., lower than character code 128, so they will be consistent across all code pages. |
Export
These settings allow you to specify how exports should be created.
EXCEL
These settings describe how Excel files should be exported.
Apply formatting to XLS and XLSX files (Y/N)
Enabling this setting will direct Monarch Data Prep Studio to apply formatting settings, such as column formats, page setup settings, and summary color settings, when tables are exported to the XLS and XLSX formats.
Enable advanced Excel features (Y/N)
This setting instructs the application to enable advanced Excel features during export
DELIMITED TEXT
These settings instruct Monarch Data Prep Studio how to read delimited text files, including:
Delimiter (Comma, tab, semicolon, space, pipe)
Text qualifier (Double quote, single quote, none)
Quote column names (Y/N)
Date format (with option to use current Windows Regional Settings) - This setting can be configured only when the Delimited Text/XML > Legacy compatibility mode - Ignore format customizations during export setting is selected.
Include column headers (Y/N)
DELIMITED TEXT/TEXT REPORTS
Append DOS end-of-file character (x1A) (Y/N)
Encoding
Code page
TEXT REPORTS
- Insert page breaks in reports
This setting allows you to insert page breaks at predefined points in multi-page reports.
- Before first page and between pages
- Never
- Between pages only
DELIMITED TEXT/XML
- Legacy compatibility mode - Ignore format customizations during export (Y/N)
Enabling this setting will cause column format customizations to be ignored during the export of numeric and date columns in favor of Monarch Classic style formatting. When using Monarch Classic formatting, numeric values are exported using the current system's localized decimal separator. Date values are exported according to the Date Format setting.
MISCELLANEOUS
- Use summary measure labels as column names during database exports (Y/N)
Enabling this setting will instruct Monarch Data Prep Studio to use summary measure labels as column names; when disabled, the underlying field name, instead of the label, is used to name measure columns.
- Include field names as the first row when using Ctrl+C to copy the clipboard
Enabling this setting will instruct the application to use column headers as the first row of any table created using the CTRL + C command.
Default Paths
SPECIFYING DEFAULT FOLDERS
By default, Monarch Data Prep Studio saves all work data, workspaces, changes lists, exports, and data source (i.e., library) catalog files to C:\Users\Public\Documents\. You can configure Monarch Data Prep Studio to save to a different folder by clicking on the Folder icon that displays beside each field. To enable folder tracking (i.e., use the last-accessed folder for subsequent file opening/saving activities), tick the check box for Track Last Folder. Note that changes to this setting are reflected only when the current Monarch Data Prep Studio session is closed and a new one is opened.
SPECIFYING THE PATH TO A DATASOURCE COLLECTION FILE
If you wish to create "snapshots" or backups of your library for easy access to previous versions of a specific data source or data sources, you can create a Datasource Collection (i.e., library) file and store it in some location of your choosing via the Application Default Settings > Default Paths tab.
You can open a saved Datasource Collection file by clicking the
icon in the Datasource Collection setting. To create a new Datasource Collection file, in the Datasource Collection setting, click the Create a new Datasource Collection file
icon to launch a file browser, and then use this browser to specify a filename and location in which to store your file. Click Save on the Save As dialog and OK on the Application Default Settings dialog to save and apply your changes. Note that when a new file is created, the default path automatically switches to this new file; no change to the previous library file occurs.
To save the current library to a Datasource Collection file without a password, click the Current Datasource Collection Save As
icon and then use the dialog that displays to specify the filename and location in which to save your file; to save this file with a password, click the Current Datasource Collection Save As with Password
icon instead.
The Create a new Datasource Collection file, Current Datasource Collection Save As, and Collection Save As with Password commands do not overwrite the original/previous library file unless you choose to (by selecting the original file instead of specifying a new file name). In this case, the file path does not change and the original file is deleted in favor of the newly created library file.
Click OK on the Application Default Settings dialog to save and apply your changes.
SPECIFYING PATHS TO MACRO COLLECTIONS
You can save macros created in your workspace to a Macro Collection file. In the Personal Macro Collection setting, click the Create a new Macro Collection file
icon to launch a file browser, and then use this browser to specify a location in which to store your Macro Collection file. Click Save on the Save As dialog and OK on the Application Default Settings dialog to save and apply your changes.
If you already have a Macro Collection file and wish to use this file instead, click on the Browse for an existing Macro Collection file
button and then use the file browser that displays to navigate to your Macro Collection file. Click Save on the Save As dialog and OK on the Application Default Settings dialog to save and apply your changes.
To access macros from a shared Macro Collection file, in the Shared Macro Collection setting, click on the Browse for an existing Macro Collection file
button and then use the file browser that displays to navigate to the shared Macro Collection file. Click Save on the Save As dialog and OK on the Application Default Settings dialog to save and apply your changes.
Conversion
These settings affect how information from text-based data sources is interpreted and converted to either the numeric or date/time format. You can specify a decimal separator (for converting text to numeric) and a date format, first year of century, and date/time extraction pattern. Selecting the Apply to current Workspace checkbox applies all of your settings to the open workspace.
Note that while most data sources, such as delimited text, excel, XML/JSON, etc., will correctly use the default column format settings to display the data. Monarch files will not use the default column format settings of the workspace since the column formats are applied in Monarch Data Prep Studio and attached to the model when exported. Files opened in Report Design (such as Text and PDF Reports) also do not take into account the default column format settings since each field created in Report Design allows the column formats to be set within Report Design. These column formats take precedence over the default column format settings of the workspace.
Display
These settings allow you to specify the default format when data are displayed in tables. As in previous settings, selecting Apply to current Workspace applies all of your selections to any open workspace in the current DPS session.
The Default Color Theme setting enables you to switch between Light Theme (the default) and Dark Theme. The Dark Theme setting is helpful when high-contrast visibility is required.
The Default Locale parameter sets the global language to be used by the application. The Default Date Format parameter specifies the default format of date/time columns.
Note that while most data sources, such as delimited text, excel, XML/JSON, etc., will correctly use the default column format settings to display the data, Monarch files will not use the default column format settings of the workspace since the column formats are applied in Monarch Data Prep Studio and attached to the model when exported. Files opened in Report Design (such as Text and PDF Reports) also do not take into account the default column format settings since each field created in Report Design allows the column formats to be set within Report Design. These column formats take precedence over the default column format settings of the workspace.
DEFAULT FONTS
The Default Fonts setting includes three tabs, each of which will help you assign a default font and font size to tables, reports, and summaries.
DATA VALUES
Setting |
Description |
Suppress zero values |
This option, when selected, suppresses zero values when viewing data. Suppressed zeros are not printed, but are exported as zero values when the Table or Summary data are exported or copied to any format except text. For text export and copy operations, the suppressed zeros are exported as space characters to retain column integrity. Note that Monarch Data Prep Studio implements zero suppression based upon the value that is returned to each cell after any rounding has been done on the value. For example, if you set the precision of a cell containing the value 0.004 to two decimal places, the application will round the value to 0.00. Since this value equates to zero, it will be suppressed if zero suppression is turned on. This is not the case in other applications, such as MS-Excel, where the underlying value 0.004 is retained and evaluated against zero. In Excel, the cell would be displayed as 0.00 and would not be suppressed, since its underlying value (0.004) is not equal to zero. |
Display nulls as text |
This option, when selected, applies the column type text to all columns with null values. |
Display null values as |
This option determines how null values should appear on screen in the Prepare window. You may enter a text string to use when representing null values. The string will be displayed using right justification. In Monarch Data Prep Studio, as in most other database applications, a null value represents an unknown value or a value that cannot be calculated. Monarch Data Prep Studio returns null values under a variety of situations:
The application exhibits the following behavior when evaluating expressions and calculations that reference one or more null values: Evaluation When a null is used in an evaluation, the expression always evaluates to False. This is the case even when a null is evaluated against another null. The reason is that null is treated as an unknown value (when two unknown values are evaluated against each other, it cannot be said that they are equal). Monarch Data Prep Studio's expression engine also does not support the constant NULL, so evaluations like the following one cannot be made: If(Amount=NULL, true result, false result) However, an indirect method of evaluation against null will work in Monarch Data Prep Studio. For example, let's say that you want to create a filter in the Table window that removes all records where the Amount field value is null. Let's say that you also know that the Amount field values are never likely to be larger than 1,000,000.00 (one million) or smaller than –1,000,000.00 (negative one million). You could use either of the following filter expressions to remove records whose values are null: Amount>-1000000 Either expression will evaluate to True for all records that contain a valid value in the Amount field, and will evaluate to False for all records that contain a null in the Amount field (since an evaluation against null returns False). Calculation When a null is referenced in a calculated field expression, the result of the expression is null. For example, the expression Amount*0.2 returns the Amount field value divided by 5 for all records where Amount contains a number. For records where Amount contains null, the expression returns null. When one or more null values are included in a measure aggregation, the null values are ignored. This can produce the desired result or an unexpected result, depending upon your point of view. For example, the Average(Amount) calculation returns the average Amount by dividing the sum of the Amount values by the Count (the number of records from which the function drew Amount values). Records for which the Amount value is null are not included in the calculation. A different result is returned by the Ratio(Amount:Count) calculation, as this calculation tallies the Amount values and the Count values in two steps. First, the sum of the Amount values is calculated, then, in isolation, the Count for all records matching the same key field values is determined. Thus, in a Ratio calculation, the Count represents all of the records, including those whose Amount field contains null. |
Highlight null cells |
This setting instructs the application to highlight null (as opposed to, for example, blank) cells in the table/summary |
Show whitespace characters |
This setting instructs the application to show whitespace characters in the table/summary. |
DEFAULT ROW HEIGHT
- Lines in column title row
This setting determines the default height for column titles in the Table and Summary windows. You may set the height from 1-12 lines. Column titles that are too long to fit on a single line will wrap to fit.
- Lines in data rows
This setting determines the default height for data rows in the Table and Summary windows. You may set the height from 1-12 lines. Data values that are too long to fit on a single line will wrap to fit.
AUTOMATIC ROW SIZING
- Automatically increase row heights to fit multi-line data
This setting instructs the application to increase row heights automatically to accommodate multi-line data.
Time Intervals
This setting allows you to set the characteristics of a fiscal year, fiscal weeks, and fiscal periods. Selecting the Apply to current Workspace check box applies all of your settings to any open workspace.
FISCAL YEAR
Setting |
Description |
Month-based (12 calendar months starting on a desginated month) |
Specifies that the fiscal year consists of 12 calendar months. |
First month of the fiscal year |
Selects the month of which the first day begins the new fiscal year. |
Week 1 starts on January 1 |
Specifies that the first week of the fiscal year begins on January 1. |
Each week starts on a specified weekday |
Defines the first day of each fiscal week and the week number of a partial week, if any, at the start of the year. |
Week-based (52 or 53 whole weeks) |
Specifies that the fiscal year consists of 52 or 53 whole weeks. You can specify the first day of each fiscal week, a reference month and day, and a rule for year start or end. |
The year is divided into four 13-week quarters |
Divides the year into four 13-week quarters and allows you to choose a week distribution pattern and quarter and period in which to place the 53rd week, if necessary. The week distribution patterns are as follows:
The year is divided into thirteen 4-week periods. |
Divides the year into thirteen 4-week periods and allows you to choose a period in which to place the 53rd week, if necessary. |
CALENDAR WEEK
Setting |
Description |
Specifies that the first full week of the year starts on the first day of the week on or after January 1.
Specifies that the week begins on a specific weekday of your choosing and allows you to set a week number for a partial week, if any, at the start of the year. |
FORMATTING
Setting |
Description |
Interval |
Lists the names of the time intervals available.
Formatting Mask
Displays the formatting mask applied to the adjacent interval. To edit the formatting mask, double-click on the desired time interval, or select an interval and press the Edit Formatting Mask button |
Sample Value
Shows the effect of the formatting masks on today’s date. To change the date that the sample value is based on, adjust the sample date calendar control accordingly. This control is located on the right-hand side of the dialog immediately below the table containing the time intervals. |
Description |
Displays a description of each time interval.
Server
Allows you to set connection settings to several servers.
Server |
Required Fields |
HTTP |
FTP |
Microsoft Azure |
If Active Directory authentication is enabled, this field becomes optional.
If this option is selected, you must enter an Account Key in order to access data from Azure Data Lake Storage Gen 2.
Clicking this button clears all cached Active Directory credentials |
Amazon S3 |
Oracle Cloud Infrastructure |
Clicking this button instructs the application to check whether the endpoint format was correctly provided |
Google Cloud Storage |
IBM Cognos Analytics |
Tableau Server |
Altair Monarch Server |
Page Setup
You can specify page header/footer settings for tables and summaries and apply the same to all tables/summaries in the current workspace. Selecting the Apply to current Workspace check box applies all of your settings to any open workspace.
PREFERENCES
Margins
Setting |
Description |
Margins (inches|centimeters) |
The Margins label at the top of the dialog displays the unit of measurement (either inches or centimeters) for all margin settings used in the current Monarch Classic session. Note: The unit of measurement is determined by the Measurement setting in the International section of the Windows Control Panel. |
Top |
Accepts a value representing the top margin. The default value is .5" or 1cm, depending upon the Windows Control Panel Measurement setting. |
Bottom |
Accepts a value representing the bottom margin. The default value is .5" or 1cm, depending upon the Windows Control Panel Measurement setting. |
Left |
Accepts a value representing the left margin. The default value is .5" or 1cm, depending upon the Windows Control Panel Measurement setting. |
Right |
Accepts a value representing the right margin. The default value is .5" or 1cm, depending upon the Windows Control Panel Measurement setting. |
Options
Setting |
Description |
Show Grid lines |
Prints the grid lines between rows and columns, as displayed on screen. |
Show Column Titles |
Prints column titles at the top of each page. |
Export Pagination
Setting |
Description |
Paper Size |
Selects the desired paper size. |
Orientation |
Selects the desired paper orientation. |
HEADER/FOOTER LAYOUT
Setting |
Description |
Page Header display box |
Displays a page header of up to 3 lines, each with text left-aligned, centered, or right-aligned text. Enter text into the boxes provided. You can insert special characters and/or variables by clicking on the left arrow button
Use custom font |
Select this box to set font options.
- Apply to current Workspace
Select this box if you wish to apply your settings to the current workspace.
Advanced
These settings allow you to specify the following:
Log level - The amount of information to store in a log file. Selecting the maximum log level allows an administrator (or Altair Support) to more easily debug issues, however this may cause the system to slow down.
Log file directory - The location in which to place log files.
Work path - The folder in which to store temporary files created while using Monarch Data Prep Studio.
Show version warnings on Workspace open - Whether Monarch Data Prep Studio should display version warnings upon loading a workspace. Selecting this box enables this setting.
File extension map - The association between a custom file extension and a supported file extension in Monarch Data Prep Studio. Data sources created using other applications may be saved to a custom file extension that must be mapped to a supported file extension in DPS to enable correct loading. Use the Add button to map as many custom extensions as necessary.
Security
These settings describe how passwords should be handled when saving workspaces in Monarch Data Prep Studio. Selecting Overwrite Workspace security settings at the bottom of the dialog instructs the application to replace all workspace security settings with those currently selected.
The following settings can be applied:
- Save credentials and sensitive connection string parameters in Workspace files and local Library items
This setting tells Monarch Data Prep Studio what to do with passwords and sensitive connection string parameters from data sources and connections in workspace files and local library items. This setting only affects local workspace and library save behavior.
You can instruct Monarch Data Prep Studio how to save passwords and sensitive connection string parameters in one of three ways:
Always - Always save the password/sensitive connection string parameter each time you save a workspace or data source without prompting
Prompt - Prompt whether to save the password/sensitive connection string parameter each time you save a workspace or data source. The following prompt displays.
Never - Never save the password/sensitive connection string parameter when the workspace or data source is saved.
- Select credentials that should be cleared from saved items
This settings specifies what types of credentials should be cleared from saved items, such as workspaces:
Password (always deleted when clearing is employed)
Account ID
User name
Service account email
Access token
Refresh token
Secret key
- Define connection string parameters that should be cleared from saved items
This list identifies strings that should be considered a sensitive connection parameter when saving details for OLE DB data sources and connectors for which the field Other Connection Options is provided in the connection dialog. When Monarch Data Prep Studio saves a connection detail and encounters the specified sensitive connection parameter (e.g., "password"), it "scrubs" (i.e., deletes) the selected string according to the save behavior defined above.Note: Microsoft Jet/ACE drivers use a specific password parameter for connection strings that must be added to the default clearing settings to maintain parity with password clearing in other sources.
This parameter is: "Jet OLEDB:Database Password"
This parameter will be added to the default parameters in its normalized, lower case form and will appear as: "jet oledb:database password."
Runtime Parameters
Allows you to define and set values for runtime parameters that can be used by all tables in all workspaces within the application.
Refer to Working with Runtime Parameters for details on defining and using runtime parameters.
About
Displays relevant information related to your Monarch Data Prep Studio application, including the version number and Altair and Datawatch copyright notices.
Clicking the Configure License button launches the Monarch License Manager, which will allow you to modify the license used with your Monarch application. If your Monarch Data Prep Studio installation is licensed via License Server, you can click License Server Credentials to launch a dialog through which you can enter the appropriate credentials and connect to a Monarch License Server instance. If your license allows it, you will also be able to check out/in your license for offline use through this tab.
