Altair® Panopticon
Creating Data Extract from Azure
Azure connector allows for retrieval of the file from an Azure blob storage. This connector allows JSON/XML/Text/Excel files to be read from the Azure blob storage.
1.     On the New Data Extract page, select Azure in the Connector drop-down list.
2.      Enter the following information:
Property
Container
Azure container where the file resides.
Account Name
Azure storage account name.
Account Key
Azure storage account key.
File Path
Azure blob file path.
3.      Select the Message Type.
4.      Select either the period (.) or comma (,) as the Decimal Separator.
   NOTE
Prepend 'default:' for the elements falling under default namespace.
5.      Click  to the fetch the schema based on the connection details. Consequently, the list of columns with the data type found from inspecting the first ‘n’ rows of the input data source is populated and the Save button is enabled.
6.      You can also opt to load or save a copy of the column definition.
7.      Click  to add columns to the Azure connection that represent sections of the message. Then enter or select:
Property
Name
JsonPath/Column Index/XPath
The JsonPath/Column Index/XPath of the source schema.
Date Format
Enabled
Determines whether the message field should be processed.
   NOTE
To parse and format times with higher than millisecond precision, the format string needs to end with a period followed by sequence of upper case S. There can be no additional characters following them.
For example: yyyy-MM-dd HH:mm:ss.SSSSSS
To delete a column, check its  or all the column entries, check the topmost , then click .
8.      Click  to save and display the details of the data extract.
9.      Click  then  to display the data preview.
