HyperWorks
HyperWorks
2023.1
  1. Home
  2. Validate
  3. Manage and Run Checks
    Use the Model Checker to configure solver validity checks, modify and create new checks and corrections, and fix modeling issues in an automatic or manual way.
  4. Supported Checks
    Supported default checks organized by solver interface.
  • What's New
  • Get Started
  • Tutorials
  • Tool Finder
  • Manage Files and Data
  • Sessions and Report Templates
  • Browsers
  • Sketching
  • Topology
  • FE Geometry
  • Meshing and Elements
  • Model Build and Assembly
  • Composites
  • Connectors
  • Morph
  • Skeleton Modeling
  • Design Space
  • Optimization
  • Design Explorer
  • Validate
  • Analyze
  • Axisymmetry
  • Concept Modeling
  • Crash and Safety
  • Airbag
  • Aerospace
  • Aeroelasticity
  • Certification
  • Squeak and Rattle Director
  • PhysicsAI
  • Results Data
  • Plot Data
  • Multibody Modeling
  • Media Files
  • Tabulate Results
  • Text Files
  • Publishing and Reporting
  • Collaboration Tools
Index
HyperWorks
2023.1
HyperWorks
  • What's New
    View new features for Altair HyperWorks 2023.1.
  • Get Started
  • Tutorials
  • Tool Finder
  • Browsers
  • Sketching
  • Topology
  • FE Geometry
  • Composites
  • Connectors
  • Morph
  • Skeleton Modeling
  • Design Space
  • Optimization
  • Design Explorer
  • Validate
    • Run Model Quality Checks on Selected Entities
      Use the Model tool to quickly run solver-related checks on all/selected entities in the model and apply auto-correction where defined.
    • Manage and Run Checks
      • Context Menu
        Provides a variety of options for working with the Model Checker.
      • Create/Edit Checks and Corrections
        Create new checks and corrections, and edit default checks and corrections.
      • Organize Checks
        Organize new and existing checks inside of a user-defined Check Folder.
      • Configure Model Checker
        Save configurations for future use, import existing configurations into your current HyperMesh session, or append configurations on top of existing configurations.
      • Run Model Check
        Find all entities in your model that failed the active checks in the Model Checker.
      • Supported Checks
        • Abaqus
        • ANSYS
        • EXODUS
        • LS-DYNA
        • Nastran
        • OptiStruct
        • PAM-CRASH 2G
        • Permas
        • Radioss
      • Sample Script
        Use this sample script to run the Model Checker in batch mode.
    • Manage Penetrations/Intersections
      Check contacts, components, or groups for element penetrations and intersections using the Penetration Check tool.
    • Find Connectivity
      Check the connectivity between two or more components.
    • Calculate Mass
      Use the Mass tool to calculate the mass, center of gravity (COG), and moments of inertia (MOI) of the model.
    • Fix Elements
      Explore the tools used to fix elements.
  • Analyze
  • Axisymmetry
  • Concept Modeling
  • Crash and Safety
  • Airbag
  • Aerospace
  • Aeroelasticity
  • Certification
  • PhysicsAI
  • Results Data
  • Plot Data
  • Media Files
  • Tabulate Results
  • Text Files
HyperWorks
HyperWorks
2023.1
  1. Home
  2. Validate
  4. Supported Checks
  • What's New
  • Get Started
  • Tutorials
  • Tool Finder
  • Browsers
  • Sketching
  • Topology
  • FE Geometry
  • Composites
  • Connectors
  • Morph
  • Skeleton Modeling
  • Design Space
  • Optimization
  • Design Explorer
  • Validate
  • Analyze
  • Axisymmetry
  • Concept Modeling
  • Crash and Safety
  • Airbag
  • Aerospace
  • Aeroelasticity
  • Certification
  • PhysicsAI
  • Results Data
  • Plot Data
  • Media Files
  • Tabulate Results
  • Text Files
Index
Supported Checks
  • Abaqus
  • ANSYS
  • EXODUS
  • LS-DYNA
  • Nastran
  • OptiStruct
  • PAM-CRASH 2G
  • Permas
  • Radioss
