Section Library
Use the automotive section library for rapid concept development in the early phases of the vehicle design process.
![](../../../images/section_library_honda_model.png)
Figure 1. Sample Body in White model (2011 Honda Accord)
![](../../../images/section_library_section_examples.png)
Figure 2. Sections from Section Library
*source : https://www.nhtsa.gov/crash-simulation-vehicle-models Honda Accord MY 2011
To access the library:
Sample Section
Each section in the section library contains:
- A Beam element with a section property
- 2D elements showing the shape of the section. The 2D element section is welded at the flanges.
- Geometric lines representing the shape of the section that can be used for concept modeling. The geometric sections are not auto-welded at the flanges.
![](../../../images/section_library_sample_section.png)
Figure 4. Sample Section
![](../../../images/section_library_section_auto_welds.png)
Figure 5. Beam Section with Auto Welds
Numbering Scheme
The section library follows a numbering scheme that is explained in detail below.
Each section can be identified by a 7-digit number
- The first digit from the left corresponds to the section’s location. It can
take values of 1, 2, or 3.
- 1: If the section is on the left side of the vehicle (for example, left-side B pillar)
- 2: If the section is on the right side of the vehicle (for example, right-side B pillar)
- 3: If the section is in the middle of the vehicle (for example, tunnel)
- The second digit from the left corresponds to the assembly of the section.
It can take values from 1 to 5.
- 1: If the section belongs to the Side Frame assembly
- 2: If the section belongs to the Roof assembly
- 3: If the section belongs to the Front Structure assembly
- 4: If the section belongs to the Front Floor assembly
- 5: If the section belongs to the Rear Floor assembly
![](../../../images/section_library_numbering_second_digit.png)
Figure 6. Second Digit Representing Different Assemblies
- The third and fourth digits correspond to parts from the assembly. Each assembly has a number of parts; for example, the list of sample parts goes to 11 in Figure 8.
- The fifth digit corresponds to the FE representation of the section. It can
take values of 0, 2, or 5.
- 0: If the FE representation is PBEAM
- 2: If the FE representation is Beam Section
- 5: If the FE representation is PSHELL
- The sixth and seventh digits correspond to the component number.
An example of the numbering scheme implemented on the left-hand side rocker/sill section can be seen in Figure 7
![](../../../images/section_library_numbering_example_1.png)
Figure 7. Numbering Scheme Example
![](../../../images/section_library_numbering_example_2.png)
Figure 8. Sample Side Frame Parts
![](../../../images/section_library_numbering_example_3.png)
Figure 9. Sample Front Structure Parts
![](../../../images/section_library_numbering_example_4.png)
Figure 10. Sample Front Floor Parts
![](../../../images/section_library_numbering_example_5.png)
Figure 11. Sample Rear Floor Parts
![](../../../images/section_library_numbering_example_6.png)
Figure 12. Sample Roof Parts
