Set Up Design Space Libraries
A Design Space library is an automotive focused library that can be used to rapidly create full vehicle architecture concept models.
![](../../../images/design_space_library_architecture.png)
View new features for Altair HyperWorks 2023.1.
Voxel meshing fills an enclosed volume with voxels (hexas) of a pre-defined size.
Promotes design exploration of early concepts and mature structures.
Edit and position nondesign parts or subsystems in your design space.
Extract an envelope by sweeping a volume.
The voxel workflow is used to generate design spaces for topology optimization. RBE3s are used to connect the design space to the structure.
Design spaces can also be connected to structural elements using tie-based contacts.
