MPDB Tool
The MPDB tool offers a complete automated post processing solution of the MPDB Frontal Compatibility Assessment load case, for Radioss and LS-DYNA output files. It also has the capability to do the MPDB compatibility assessment for physical test data (scanned data) written out in STL format.
![](../../images/post_processing/mpdb_tool_figure.png)
Figure 1. Figure from Carhs Safety Companion 2019
![](../../images/post_processing/mpdb_icon.png)
![](../../images/post_processing/mpdb_safety_menu_hvx.png)
![](../../images/post_processing/mpdb_safety_mpdb_selection.png)
![](../../images/post_processing/mpdb_proj_tool_dialog_hvx.png)
Figure 4.
- The definition of the rating area of the PDB front face
- The calculation of the standard deviation of the post-test barrier deformation
- The calculation of a bottoming out scenario
- The calculation of the Occupant Load Criterion (OLC)
- The calculation of the Compatibility Modifier
- Automatic Results report generation
