Output Parameters
The output parameters section of the Expression Builder allows you to define the data type label and output for the newly created result.
![](../../images/post_processing/hv_expression_builder.png)
Label
The label will become the data type name, and must be unique for the analysis. This label defines the user-defined data type name that will appear when selecting results from the results browser or from the post-processing panels.- Character Reference
- Character Name
- Ampersand
- Left Angle Bracket
- Right Angle Bracket
- Quotation Mark
- Apostrophe
- Left Square Bracket
- Right Square Bracket
- Left Curly Brace
- Right Curly Brace
- Backslash
- Colon
![](../../images/icons/add-24.png)
