Review the Hotspot Search Results
Review the hotspot search results in a tabular form by clicking the table icon
A table containing a hotspots list is displayed in the modeling area.
Figure 1. - Optional:
Undock the table from the guide bar to drag and move it around the screen, by
clicking the
icon on top right corner of the table.
Show or hide the hotspots from the modeling window using the row
highlighter.
Figure 2. -
To show additional data in the hotspot review table, right-click on the column
header in the table and select the required data about the hotspot.
Note: In the HyperView - MultiCore profile, you can run a hotspot search based on one result (for example, stress) and display additional results (for example, strain) at the hotspot locations. To do this, make sure you have cached all the desired results upfront.
Figure 3. -
You can also hide the unwanted components from showing up in the hotspot tour,
by clicking the
icon on the guide bar to open the Show hide tool.
After selecting the components or elements to hide from screen, right-click twice to get back to the Hotspot Finder guide bar and hit the Play button.Note: The entities hidden using this option will stay hidden as long as you are in the hotspot tour. -
Change the hotspots viewing mode using the drop-down menu on the guide
bar.
Figure 4. -
Navigate through the hotspots using the First,
Previous, Next, or
Last buttons located on the guide bar
