Constant Radius
A Constant radius event simulates a vehicle driving in a circular path, typically with increasing speed. The event predicts the vehicles roll and understeer characteristics with increasing lateral acceleration.
The event maintains a constant turn radius and varies the vehicle velocity to produce increasing amounts of lateral acceleration. Steering and torque controllers maintain the path and the speed of the vehicle through the event.
The constant radius event is supported by the Cars & Small Trucks, Heavy Trucks, and Two-Wheeler vehicle libraries. Automated output reports are available to plot the results.
![](../../images/post_processing/constant_radius_diagram_mvx.png)
Figure 1. Constant Radius Event
Parameter Name | Description |
Units | Describes the Length, Velocity, and Acceleration units.
Radius | Radius of the circle that the vehicle CG follows during the constant radius portion of the event. |
Initial straight | Straight distance section of the event before the constant radius portion. |
Initial velocity | Initial vehicle velocity. |
Final velocity | Final vehicle velocity desired in the simulation. |
Initial lateral acceleration | Estimated initial lateral acceleration. This value is not editable and is calculated using the initial speed and the radius parameters. |
Final lateral acceleration | Estimated final lateral acceleration. This value is not editable and is calculated using the initial speed and the radius parameters. |
Turn direction | Direction the vehicle turns during the event (as seen by the driver). |
Transient time | Time duration for which vehicle accelerates/decelerates after achieving steady state. |
Controller Settings
- Non-leaning events (Cars/Trucks)
- LONGITUDINAL – TRACTION CONTROLLER SETTINGS
- Use additional control: Enables the additional feedback control for the traction
control. The gains for the controller can be edited by toggling this check
box.
Kp Proportional gain for the feedback PID controller Ki Integral gain for the feedback PID controller Kd Derivative gain for the feedback PID controller
box.
- Leaning events (Two-wheelers)
box.
box.
Signal Settings
Use the signal settings to set minimum, maximum, smooth frequency and initial values for Steering, Throttle, Brake, Gear, and Clutch signals output by the driver.
The smoothing frequency is used to control how fast the Driver changes signals. Only closed loop control signals from the Driver are smoothed. Open loop signals are not smoothed.
Road Settings
- Flat Road
- Uses a flat smooth road for the event with no required road file.When the Flat Road is selected, the Graphics Setting option is available with the following parameters:
- View path centerline: Enables the visualization of the event path.
- This check box is disabled for open loop events without a path.
- View grid graphics: Enables the visualization of the road grid graphics.
- When view grid graphics check box is toggled, road grid parameters can be edited in the Grid Settings tab.
Grid length Defines the length of the road. Enter a positive value in the model units. Grid Width Defines the width of the road. Enter a positive value in the model units. Grid X offset Gives a distance offset to the road graphics in the longitudinal direction. Enter a positive value in the model units. Grid Y offset Gives a distance offset to the road graphics in the lateral direction. Enter a positive value in the model units.
- Road File
- The road file option enables the selection of a road file to be used in the event. Using this option, all tires in the model consider the event specified road file instead of the file included in the tire entities.
- Tires
- Using Tire as road selection option, the road file specified in the tire entity is used in the events simulation.
Automated Output Report
Report Name | Report Signals |
Steering Input and Accelerations |
Vehicle Velocities |
Vehicle Slip Angles |
Roll Angle |
Steer/Suspension Travel |
Steering, roll and torque |
Vehicle Slip vs. Acceleration |
Steering Wheel Angle vs. Vehicle Sideslip Angle | |
Tire Lateral Slip |
Vertical Tire Forces |
Lateral Tire Forces |
Longitudinal Tire Forces |
Wheel Aligning Torques |
Vertical Tire Forces vs. Lateral Acceleration |
Lateral Load Transfer |
