HyperWorks
HyperWorks
2023.1
  1. Home
  2. Plot Data
  3. Polar Chart
  4. Define
    Edit existing curves and add new curves to the current plot.
  5. Use Math as a Data Source
  • What's New
  • Get Started
  • Tutorials
  • Tool Finder
  • Manage Files and Data
  • Sessions and Report Templates
  • Browsers
  • Sketching
  • Topology
  • FE Geometry
  • Meshing and Elements
  • Model Build and Assembly
  • Composites
  • Connectors
  • Morph
  • Skeleton Modeling
  • Design Space
  • Optimization
  • Design Explorer
  • Validate
  • Analyze
  • Axisymmetry
  • Concept Modeling
  • Crash and Safety
  • Airbag
  • Aerospace
  • Aeroelasticity
  • Certification
  • Squeak and Rattle Director
  • PhysicsAI
  • Results Data
  • Plot Data
  • Multibody Modeling
  • Media Files
  • Tabulate Results
  • Text Files
  • Publishing and Reporting
  • Collaboration Tools
Index
HyperWorks
2023.1
HyperWorks
  • What's New
    View new features for Altair HyperWorks 2023.1.
  • Get Started
  • Tutorials
  • Tool Finder
  • Browsers
  • Sketching
  • Topology
  • FE Geometry
  • Composites
  • Connectors
  • Morph
  • Skeleton Modeling
  • Design Space
  • Optimization
  • Design Explorer
  • Validate
  • Analyze
  • Axisymmetry
  • Concept Modeling
  • Crash and Safety
  • Airbag
  • Aerospace
  • Aeroelasticity
  • Certification
  • PhysicsAI
  • Results Data
  • Plot Data
    • Working with Plots
      Learn how to manipulate plot data using the Plot Browser and other user interface tools and options.
    • Line Chart
    • Bar Chart
    • Complex Chart
    • Polar Chart
      • Define
        • Add a Curve
        • Copy a Curve from an Active Window
        • Cut a Curve from an Active Window
        • Display the Curves Dialog
        • Paste a Curve from an Active Window
        • Rename a Curve
        • Set the Vector Source to File
        • Turn a Curve On or Off
        • Use Math as a Data Source
      • Values
        Retrieve individual point data on any curve in the active window. When a point is selected, the point data is displayed on the panel.
      • Datums
        Add horizontal and vertical datum lines to plots.
    • Vector Chart
    • Radar Chart
    • 3D Chart
  • Media Files
  • Tabulate Results
  • Text Files
HyperWorks
HyperWorks
2023.1
  1. Home
  2. Plot Data
  3. Polar Chart
  4. Define
  • What's New
  • Get Started
  • Tutorials
  • Tool Finder
  • Browsers
  • Sketching
  • Topology
  • FE Geometry
  • Composites
  • Connectors
  • Morph
  • Skeleton Modeling
  • Design Space
  • Optimization
  • Design Explorer
  • Validate
  • Analyze
  • Axisymmetry
  • Concept Modeling
  • Crash and Safety
  • Airbag
  • Aerospace
  • Aeroelasticity
  • Certification
  • PhysicsAI
  • Results Data
  • Plot Data
  • Media Files
  • Tabulate Results
  • Text Files
Index
  1. From the Define panel, under Source, select Math.
  2. Define the vector using the curve calculator to create a mathematical expression.
