Select Plot Entities
Use the entity selector to specify the plot entity to select.
![](../../images/hypergraph/plot_entity_selector_menu.png)
For example, if an entity selector is set to Curves, only curves are available for selection.
When All is selected, you click-and-drag and box around all plot entities in the modeling window to select them simultaneously.
Please see Selection for more information on entity selection.
