Restriction: Batch run xml is not supported for Spot and Seam Weld
Fatigue.
From the Evaluate tool group, click the
Run Analysis tool.
The Evaluate dialog opens.
In the Evaluate dialog, click
Export.
Tip: The xml file generated via export can be imported through the
File menu to configure the HyperLife Fatigue
setup. The import option automatically facilitates:
Setup of fatigue context
Setup of material context
Setup of Load Map context
A folder containing the .xml file is created for
the run at Fatigue/runhistory.
Create a batch job.
From the Utilities tool group, click the Batch
tool.
Figure 3.
The Batch Run dialog opens.
In the Batch Run dialog, click and
browse for the previously created .xml file.
Click Submit Run.
A run log file (*.log) containing information about
the run setup and status is written to the run folder.
Analyze the log file.
The log file summarizes the following details from the executed run:
