Solver Conversion
Enhancements
Abaqus to OptiStruct Conversion
AXIAL,CARDAN Joint was converted to AXIACARD.
AXIAL,ROTATION Joint was converted to AXIAROTA.
LINK,ROTATION Joint was converted to RLINROTA.
SLOT,ALIGN Joint was converted to INLIORIE.
SLIDE,PLANTE Joint was converted to CARDANINPLCARD.
SLIDE-PLANE Joint was converted to ROTATIONINLROTA.
JOIN,CARDAN Joint was converted to RPINCARD.
CARTESIAN,CARDAN Joint was converted to CARTCARD.
VARIABLE MASS SCALING was converted to TSTEPE.
Abaqus to Radioss Conversion
HYPERELASTIC,MARLOW was converted to /LAW111
BOUNDARY,TYPE=VELOCITY was converted to /IMPVEL
CLOAD was converted to /CLOAD
AMPLITUDE, NAME =curve, DEFINITION=SMOOTH STEP was converted to /FUNC_SMOOTH
LS-DYNA to OptiStruct Conversion
*CONTROL TIMESTEP converted to NLEXPL
*CONTACT_AUTOMATIC_SINGLE_SURFACE_ID converted to CONTACT, AUTO
*CONTACT_AUTOMATIC _SURFACE_TO_SURFACE converted to CONTACT, AUTO
Permas to OptiStruct Conversion
MATERIAL,ANSIO was converted to MAT9.
Radioss to OptiStruct Conversion
/DT/NODA/CST converted to ANALYSIS NLEXPL
/INTER/TYPE25 converted to CONTACT, AUTO
/RUN converted to NLEXPL, TTERM
