Altair OptiStruct 2023.1 Release Notes
Highlights
- Brittle damage
- Truss layout optimization
- Johnson-Holmquist material
- Material for concrete, soil, and geomechanics- Mohr-Coulomb material
- Drucker-Prager material
- Kinematic and mixed hardening for LGDISP shells
- Encrypt entire INCLUDE files
- Neuber stress response for topology and free-size optimization
New Features
- MATMDS with INISTRS
- Initial stress (INISTRS) is now supported for elements referencing MATMDS material (interfacing with Altair MultiScale Designer).
- Mohr-Coulomb Plasticity model
- The Mohr-Coulomb Plasticity model is now available for implicit nonlinear analysis. This can be activated using the MC continuation line on the MATS1 Bulk Data Entry. The COHE field is used to define cohesion, the FRICA field defines the friction angle, and DILA can be used to define the dilatancy angle. This is supported for nonlinear static and nonlinear transient for both small and large displacement analysis. It is only supported for solid elements. Temperature dependency is not currently supported.
- Drucker-Prager Plasticity model
- The Drucker-Prager Plasticity Model is now available for implicit nonlinear analysis. This can be activated using the DP continuation line on the MATS1 Bulk Data Entry. The YIELD field defines the initial yield strength of the material, which is used to calculate the cohesion value. The TYPE field determines how the cohesion value is calculated; it can be set to COMP (compression), TENS (tension), or COHE (cohesion). Based on the value of the TYPE field, the corresponding approach is used to calculate the cohesion value using the YIELD strength. The FRICA field defines the friction angle, and DILA can be used to define the dilatancy angle. This is supported for nonlinear static and nonlinear transient for both small and large displacement analysis. It is only supported for solid elements. Temperature dependency is currently not supported.
- GPSTRESS support for FAILURE output
- A new location option called GPS is available on the FAILURE I/O Option. This allows the grid point stress values to be used to calculate the failure output. This is different from using the CORNER location; for GPS, the stresses are first averaged at each grid before being used for failure calculation.
- Kinematic and mixed hardening for LGDISP for shells
                            Kinematic hardening (HR=2) and mixed hardening (HR=3) on the MATS1 Bulk Data Entry are now supported for shell elements in large displacement nonlinear analysis.
- Rayleigh damping for MCOHED in linear transient analysis
- Rayleigh damping via the ALPHA field on the RAYL continuation line is now supported for the MCOHED cohesive material in linear transient analysis.
- Alternate formulation for CSHEAR
- An alternate formulation for CSHEAR elements is now available and can be activated via PARAM,SHEARALT,YES. This formulation can improve results when shear panels are distorted and enhance stress results in free thermal expansion.
- JOINTG elastic force output in .joint format
- Elastic forces are now output for JOINTG elements in the .joint file (OPTI format).
- Buckling analysis under inertia relief
- Buckling analysis under inertia relief is now available. PARAM,INRELBCK,1 can be used to allow buckling analysis under inertia relief, and SUPORT degrees of freedom from inertia relief are used for buckling analysis.
- Initial plastic strain input
- Initial plastic strain input is now available via the INIPS Bulk Data Entry and Subcase Information Entry. With INIPS, you can directly input the initial plastic strain or reference an external H3D file which contains the initial plastic strain to be applied. The IPSADD Bulk Data Entry is also available to combine multiple INIPS Bulk Data Entries.
- Brittle damage
- Brittle material damage definition is now available via the MATBRT Bulk Data Entry for explicit analysis. The tensile and shear crack modes are available. For the tensile crack mode, the STRN option allows crack opening to be expressed as principal stress versus crack opening strain, DISP option for principal stress versus crack opening displacement, and ENER option for crack opening in the form of principal stress and fracture energy.
- Johnson-Holmquist material is now available to model brittle material behavior for explicit analysis. It can be activated using the JHOLMQ continuation line on the MATS1 Bulk Data Entry. This is currently only supported for solid elements.
- Component-based mass table in .out file
- HyperMesh component-based mass table is now printed in the .out file as part of the printing from OUTPUT,MASSCOMP for explicit analysis. The component ID, mass, added Mass, and component name are available in this table.
- TLOAD2 support
- TLOAD2 load input is now supported for explicit analysis.
- Default integration scheme for CHEXA8 in explicit analysis switched to URI
- The default integration scheme for CHEXA8 elements in explicit analysis has now been switched from AURI (Average Uniform Reduced Integration) to URI (Uniform Reduced Integration).
- Vector-based filtering for threshold-based stress output in transient, steady-state, FRF, and random
- Vector-based filtering is now available for threshold options to filter stress output. The VFLTR keyword should added to the STRESS output request along with one of the filtering options, THRESH, RTHRESH, TOP or RTOP. For elements which satisfy the filtering threshold condition at any time-step or frequency, they are output for the full time or frequency domain. This is currently supported for transient, steady-state, frequency response, and random response analysis.
- ACPOWER and ACINT support for APML
- Acoustic Power (ACPOWER) and Acoustic Intensity (ACINT) are now supported for Adaptive Perfectly Matched Layer (APML) acoustic analysis. Sound pressure output was made available in previous releases for APML.
- GPSTRESS output for random response
- Grid point stress results are now supported for random response analysis.
- CONTACT support for internal superlements
- CONTACT is now supported for internal superelements. The contact can be a part of either the superelement or the residual part of the model.
- Ignore frequency-dependent material MATF# using PARAM,MATFREQ,OFF
- Frequency-dependent material defined via MATF# entries can be ignored from the run by setting PARAM,MATFREQ,OFF.
- Alternate method to improve performance for modal FRF with frequency-dependent materials (AMSFRMAT)
- An alternate method is available via PARAM,AMSFRMAT,YES for modal frequency response solutions when a large number of frequency-dependent materials (> 1000 dof) are present and AMSES is used as the eigensolver. This alternate method can help improve the performance of the modal frequency response solution.
- Total time length for steady state analysis
- The total time length for steady state analysis can now be defined via the TTIME field on the STEADY Bulk Data Entry. The default is 1.0 divided by the minimum loading frequency used for the steady state analysis.
- Additional output support for steady state analysis
- The pressure output (including mic pressure for IE and APML) and element force output are now supported for steady state analysis. The displacement, stress, and ERP results are already supported for steady-state analysis.
- Enhanced support for stress output in random response
- The stress output for random response analysis has been enhanced with the following grouping:
- Back-calculation for fatigue analysis
- Back-calculation for fatigue to calculate scaling factor for a particular target life is now supported and can be activated by requesting FOS output, followed by setting target life in the TGLIFE field of the FOS continuation line on FATPARM Bulk Data Entry. The METHOD field should be set to SCALE for back calculation. The results are supported in the H3D and OPTI formats.
- Cyclic stress standard error (SEc) in EN fatigue
- The standard error of cyclic stress-strain curve is now supported via the SEc field in the EN material section of the MATFAT Bulk Data Entry. The value of SEc is used to modify the cyclic strength coefficient (K’).
- Critical plane support in fatigue
- The CRTPLN option can be specified for the COMBINE field to activate critical plane approach for random response (SN & EN), sine-sweep (SN & EN), sine-sweep on random, sine on random, multiple sine tones (SN), and transient (SN & EN) fatigue analysis.
- OUTPUT,MATRIX support for linear transient heat transfer
- The heat capacity matrix, the conductivity matrix, and the convection matrix are now available in the corresponding *_full.mat file. Options such as dense or sparse matrix output and user-defined precision are available.
- With truss layout optimization, you can find the optimal truss-based
                            layout for a given design space. It is useful for applications where
                            structures include trusses (for example, architectural industry for
                            building design). The truss layout optimization is activated by the
                                DTRUSS Bulk Data Entry. It also contains the
                            parameters to control the optimization run, such as permissible stress
                            bounds for the truss elements, truss cross-sectional area limits,
                            symmetry and buckling constraints. Currently the presence of the
                                DTRUSS entry implies the entire model is part of
                            the design space. This is supported for shell and solid elements and for
                            linear static analysis. Note: The trusses are represented by CROD elements for truss layout optimization.
- Electro-thermal responses for optimization
- Thermal compliance (RTYPE=TCOMP on DRESP1) and temperature (RTYPE=TEMP) responses are supported for electro-thermal analysis. Joule heating is taken into account in sensitivity analysis. Topology, free-size, size, free-shape, shape, and topography optimization are supported.
- Overhang constraint support in level set optimization
- Overhang constraints are now supported in level set optimization.
- MAXDIM and MINGAP are now supported in level set optimization
- MAXDIM and MINGAP are now supported in level set optimization. MINGAP should not be set larger than MAXDIM for level set.
- NORM-based response sensitivity output added to OUTPUT,ASCSENS
- Sensitivity output for NORM-based responses are now available in the *.asens file when OUTPUT,ASCSENS is requested.
- Neuber stress responses are now supported for topology and free-size optimization. Shell and solid elements are supported. The stress-norm approach is used.
- An alternate encryption tool is now available to encrypt entire include files. This allows for a more versatile and easy-to-use method to encrypt data in the OptiStruct model. The entries currently supported for encryption are properties, materials, and their associated tables. Once the new encryption tool is used to create an encrypted version of an include file, the encrypted include file can be shared with other users and it can be directly included in the base model (similar to how the unencrypted include file was included). OptiStruct completes the run without any additional user-input.
- Recovery of results on internal SE part
- The MODEL card is now supported for internal superelements. Results can now be recovered for the internal superelement part. Additionally, an SEDR entry can be used to define the superelement parts for which results should be recovered.
- On-the-fly output enhancements
- The following are now supported for On-the-fly output:- VON mises stress option for 1D
- Plastic strain for implicit
- Factor of safety (FAILURE)
- CBUSH element force
- SET creation with Cylindrical bounding box
- A GRID SET can now be created by identifying a cylindrical bounding box and all grids present within the bounding box are a part of this SET. The SUBTYPE should be set to BBOXC and center grid points of each circular side of the cylinder are specified via G1/Xi,Yi,Zi and G2/Xj,Yj,Zj. The RADIUS field is used to define the radius of the cylinder.
- Statistics output for Neuber stress
- Statistics output, which includes maximum, time of maximum, arithmetic mean, RMS, variance, and standard deviation are now supported for Neuber stresses.
- RIGID-based grid SET
- A GRID SET can now be created by using the SUBTYPE=RGTYPE and then the available options can be set to RBAR, RROD, RBE1, RBE2, RBE3, RSPLINE, RSSCON, RJOINT, and RBODY. These options can be specified individually or in combination with each other. An additional option ALL is available to choose all rigid elements for inclusion in the GRID set.
- Neuber stress/strain output at both Z1 and Z2 for shells
- Neuber stress and strain are now output at both Z1 and Z2 sides of shells.
- Element strain output support in OP2 and PUNCH for normal modes analysis
- Element strains are now output in OP2 and PUNCH formats for normal modes analysis.
- LDM and multi-level DDM no longer supported for nonlinear analysis
- Load-decomposition method (LDM) and multi-level DDM are no longer supported for nonlinear analysis. Domain decomposition method (DDM) is still supported for nonlinear analysis and can significantly improve performance.
- Store user data on MAT1 material
- User material data can now be stored on the UDATA continuation line. The data can be stored in pairs, with each parameter associated with its name followed by its value.
- Intel MPI version upgraded from 2021.2 to 2021.10
- The Intel MPI version has been upgraded from 2021.2 to 2021.10.
- Missing DMIG ERRORs can now be switched to WARNING
- ERRORs when DMIGs matrices referenced in the subcase section are not present can now be converted to WARNINGs with SYSSETTING(UNREFSID=WARN).
- Enhanced RBE3 formulation for nonlinear LGDISP analysis
- The RBE3 formulation is enhanced for nonlinear LGDISP analysis and shows improved handling of RBE3s with released independent translational degrees of freedom.
- Clear flags for continuation lines on TSTEP Bulk Data Entry
- The time integration continuation line now has a clear flag,
                                TINT, to identify the beginning of input
                            parameters for time integration. Similarly, the TSTEP
                            flag now indicates the beginning of input parameters for time-stepping.
                            This allows for easier handling during import/export in HyperMesh and
                            also for manually entering data on the TSTEP entry.
                            Therefore, the fields in the new format are offset to the right but one
                            field. Note: The old format without these new flags is still accepted by OptiStruct.
- Add Comments in the Bulk Data section of the input file
- Comments can now be added in the Bulk Data section of the input file using the COMMENT ON/OFF Bulk Data Entries. Any Bulk Data Entry lines between COMMENT ON and COMMENT OFF are excluded from the analysis.
- Quick and simplified model summary in .json file
- A quick and simplified model summary is available in a separate
                                <filename>_summary.json file when using the
                                -summaryrun option. The .json file contains an overall summary of all major entities in the model (such as number of grids, elements, properties, materials, and so on). It also contains subset summaries for each entity accordingly (such as an elements summary which contains the breakdown of number of elements of each type). This can provide some quick information which can be used to plan the required resources for the job (such as required memory, disk space, number of cores, and so on).
- SYSSETTING to issue an Error when the sum of material damping is negative for an element
- If SYSETTING(NEGGEERR=YES) is set, an error is now issued when the sum of material damping contributions for any element is negative. The damping contributions which are considered for calculating the sum are: damping from NSGE, GE on MATi data, and PARAM,G. Note that the GE damping on frequency-dependent material is also considered for the calculation.
- Combined 2D and 3D stress/strain output in H3D for Von Mises or Maximum Principal
- The stress and strain results for both 2D and 3D elements are now combined for easier visualization when Von Mises or Maximum Principal results are requested.
Resolved Issues
- The algorithm for automatically handling the normals for panels in ERP has been enhanced to properly handle panels that contain ribs or similar features.
- OptiStruct runs using Compose on Windows no longer fail due to missing library error.
- A programming error is no longer issued when GM method is used for CMS generation, AUTOSPC is turned off, and zero-stiffness degrees of freedom are used for interface degrees of freedom (ASET/BSET). A clear error message is now issued that there is no stiffness associated with the interface degree of freedom for GM method.
- Some high contact pressure is no longer localized at particular locations in the model due to improvements to continuous sliding (CONSLI) contact search.
- A programming error is no longer issued when the model contains NSM with PARAM,INREL,-2, static subcases, and damping.
- A programming error is no longer issued when Topography optimization with ERP responses is run with FREQ3 entry.
- A clear error message is now printed when GE is not defined on PCOMPG during SE reduction and K42GG is specified in residual run to use damping matrix.
- Material parameters printed in .prop and .h3d files are now consistent with the .out file for size optimization.
- Licenses are now returned when an OptiStruct job is paused using the ACC pause button or using the <filename>.ossleep file. Once the job is resumed, the licenses are requested again.
- A crash no longer occurs in RESFRC module when an NLSTAT analysis with both MATMDS and MATS1 in the model.
- Rigid elements (RBE2 and RBE3) are now properly removed in the *_impl.h3d file when they are excluded via MODCHG. This has now been fixed.
- When RBE3 elements are removed with MODCHG for NLSTAT analysis, the RBE3 elements are now properly removed from inside the analysis along with being removed from the regular H3D file. Previously, unexpected results occurred similar to those seen if the RBE3 element continued to exist.
- A programming error no longer occurs when optimization with component-level mode tracking with AMSES is conducted for a model.
- Non-converged results based on incremental NLOUT output for Nonlinear analysis are now properly written to the H3D file.
- A programming error for shape optimization, which occurred when the run had an increase in the non-zero degrees of freedom from one iteration to the next and led to memory expansion beyond the available memory, no longer occurs.
- NEUBB stress response no longer ignores the Z2 side of the shell during optimization.
- A programming error no longer occurs when TEMP load is applied in transient analysis with SPCFORCE output request.
- A programming error no longer occurs when CFAILURE output is requested for MAT9OR referencing PSOLID elements.
- A crash no longer occurs when modal frequency response analysis with pretension is run for rotor dynamic analysis.
