Altair HyperView
New Features
- Read new Element Type
- Read MSC NASTRAN and NX NASTRAN CPYRAM Elements.
- SOL 400
- Support SUBCASE, STEP and SUBSTEP Organization, for OP2 and HDF5 Formats.
- SOL 146 (Gust Response)
- Split Random Gust Response’s PSD, RMS Cumulative RMS (CRMS), Positive Zero Crossing (N0) and Auto-Correlation Function in different Load Cases.
- Random Response
- Split PSD, RMS Cumulative RMS (CRMS), Positive Zero Crossing (N0) and Auto-Correlation Function in different Load Cases.
- Read more NVH Results
- Read Sound Pressure, RMS Sound Pressure, Sound Pressure in dB and Sound
                            Pressure in dBa, from OP2 and HDF5 Files.Read Equivalent Radiated Power (ERP), from OP2 and HDF5 Files. Read Vibration Intensity (VINTENSITY), from OP2 and HDF5 Files.
Enhancements
- Read Random Gust Response’s Positive Zero Crossing (N0) and Auto-Correlation Function (AUTO), for OP2 and HDF5 Formats.
- Random Response
- Read Positive Zero Crossing (N0) and Auto-Correlation Function (AUTO), for OP2 and HDF5 Formats.
- GPSTRESS and GPSTRAIN
- Read GPSTRESS and GPSTRAIN Results for 2D Elements, from OP2 and HDF5 Files.
Known Issues
- Rad Heat Transfer results, for HDF5 Files.
Resolved Issues
- Correct Elemental Results’ Transformation for OptiStruct’s, MSC NASTRAN’s and NX NASTRAN’s CPENTA Element.
- Read PSD and RMS Results for Velocity and Acceleration Results.
- Read RMS Results for Beam Elements.
- Read Stress Results when < PARAM, OMID, YES > is used.
- Read correct Composite Material Results, for Frequency Response, from OP2 Files.
