Aided mesh: définition (structure)
Definition
The aided mesh is defined by :
- the state (activated / inactivated)
- certain parameters
State
The aided mesh is activated by default.
When it is activated, the parameters of the "Aided" (specific to the aid) type are assigned to all the free geometric entities of the project. The entities that contain mesh data (instance created and assigned by the user) are not controlled by the aided mesh.
The table below sums up, the various ‘ aided'parameters administered by aided mesh, the mesh tools to which they correspond, the entities on which they are assigned, their type and their value.
| Aided Parameters | Corresponding tools | Impacted geometric entity | Type | Value |
| Aided mesh point | point discretization | point | dynamic (by default) | value synchronized by aid in function of project size |
| uniform | Length of elements | |||
| Aided meshline and aided mesh generator |
 | absolute deviation |
| Relative deviation | 0.0<d<1.0 | |||
| Aided relax line | relaxation | line | Ø |
| Aided relax face | face | Ø |
| Aided relaxvolume | volume | Ø |
| Aided shadowface | shading | face (3D) | Ø |
