2D sketcher: move a selection
Move a selection
After you have made a selection of entities, it is possible to displace it graphically by clicking over then while maintaining the click to move the mouse.
During the displacement, without depressing the click of the mouse, the user can visualize the displacement that he is going to perform.
The selection of displacement requires introducing several constraining rules concerning the arcs.
- Accurate movement (equivalent to the dimension of a subdivision of a grid cell) : Ctrl + Arrows (keyboard)
- Very accurate movement (equivalent to the distance between the magnetization points of the grid : Shift + Ctrl + Arrows (keyboard)
Move an Arc 2 points with center
Here are the rules of displacement of the entities of an isolated arc 2 points with center.
| Type of move | Arc 2 points with center (alone) |
| Move an extremity point |
| Move the center point |
| Move the arc |
Move an Arc 2 points without center
Here are the rules of displacement of the entities of an isolated arc 2 points without center .
| Type of move | Arc 2 points without center (alone) |
| Move the arc |
Move an Arc 3 points
Here are the rules of displacement of the entities of an isolated arc 3 points.
| Type of move | Arc 3 points (alone) |
| Displacement of the 1 st point extremity |
| Displacement of a point extremity | |
| Displacement of the 2nd point extremity | |
| Displacement of the arc |
Arc movement: conflicts
These rules are discussed again due to interdependences between the arcs resulting in complexity increasing rapidly.
Choices of priorities are implemented for the case with several interdependences. For example, the point center of an arc can be the point extremity of another one. In this case, the rule of the point center becomes prevalent over that of point extremity.
The configurations with too much interdependency are not displaceable. In this case,
            during the displacement the cursor becomes the following symbol
Detection direction lines
During the movement of a selection, a point of the selection must detect direction lines (graphic help, horizontal and vertical lines detected…). This point is called “ grip point ”. It is identifiable by a red highlight and is randomly chosen.
The user can change the movement grip point by using the arrow keys (keyboard) .
