Coordinate system: by default
Default coordinate system
To facilitate the work of the user, Flux PEEC provides a working coordinate system. It is created for every new project. It is possible to rename, to modify or to delete it.
Predefined coordinate system
The default working coordinate systems proposed to the user are:
- of cartesian type
- defined with respect to the global coordinate system using:- for length unit the millimeter
- for angle unit the degree
| 3D domain | |
| Coordinate system | Characteristics |
| XYZ1
                            | Origin of coordinate system:
 Rotation angle:
