Geometry building process
Outline
An outline of the geometry building process is presented in the table below. The different steps are detailed in the following blocks.
| Step | Description |
| 1 | Device analysis |
| 2 | Definition of the study domain |
| 3 | Preparation of the geometric construction tools |
| 4 | Ascending construction of the geometry |
| 5 | Regrouping in regions |
Device analysis (1)
The first step of the geometry building process is the device analysis :
- to define the study domain, and
- to prepare the geometric description
The questions that could arise at this level, before starting the description itself, are grouped in the tables below (non exhaustive list).
| Analysis to: | Device features |
| define the study domain |
| prepare the geometric description |
| Analysis to: | Is it necessary |
| prepare the mesh |
| prepare the physical description |
Next steps (2, 3, 4, 5)
The other steps of the geometry building process are described in the table below.
| Step of … | The user | ||
| creates… | builds… | assigns… | |
| Defining the study domain (2) | the symmetries the periodicities the infinite box | ||
| Preparing the geometric building tools (3) | the geometric parameters the local coordinate systems the transformations | ||
| Ascending construction of the geometry (4) | the points the lines | the faces the volumes | |
| Regrouping in regions (5) | the point regions the line regions the face regions the volume regions | the regions to points, lines, faces, volumes respectively | |
Operations order
The different steps were presented in a “chronological” building order.
In practice, the geometry building process is not always linear and the user proceeds by successive steps. In this case, he makes “go and return” between different steps.
