Isotropic / anisotropic materials
Introduction
The studied materials can be isotropic or anisotropic. In other words, the magnetic behavior of the material is as follows:
- independent of the direction of the applied field (isotropic material)
- dependent on the direction of the applied field (anisotropic material)
These two cases are presented in the following sections.
Isotropic materials
Isotropic materials are characterized by a magnetization law independent of the direction of the applied field.
The  and
 and  vectors
are always collinear.
 vectors
The dependence between  and
            and  is a scalar
            relationship, which is written as: J= σ.E or E= ρ.J
 is a scalar
Anisotropic materials
Anisotropic materials are characterized by a law, which is dependent on the direction of the applied field.
The  and
 and  vectors
are not collinear.
 vectors
are not collinear.
 and  is a
vector relationship, which is written as:
 is a
vector relationship, which is written as:  or
 or
with σ  conductivity tensor:
or ρ resistivity tensor:
… in Flux
The model provided in Flux is a simplified model.
The vector dependence between  and
 and  which is written as:
             or
 or  can therefore be
expressed:
 can therefore be
expressed:
               either under the form of three curves: Jx(Ex), Jy(Ey), Jz(Ez) The conductivity tensor is then written:
               or under the form of three curves: Ex(Jx), Ey(Jy), Ez(Jz) The resistivity tensor is then written:
