Magnetic behavior of materials: definitions
Definition
The macroscopic dependence linking the local values of the vector quantities magnetization M (or magnetic polarization J ) and the magnetic field strength H in any point of a material is called the law of material magnetic behavior.
This law renders the fact that the magnetization of matter is modified under the effect of a magnetic field.
This law is written in the form:
                with the magnetization vector with the magnetization vector
                with the polarization vector with the polarization vector
where χm is the scalar or the tensor of magnetic susceptibility*
Notation
The magnetization law is written in the form:
where μ is the scalar or the tensor of permeability
Complex permeability
In the case of harmonic applications, a complex representation of permeability is used.
The quantity μ can be expressed by the complex permeability:
μ = μ' - j μ"
where:
- μ' corresponds to the real part of the complex permeability
- μ" corresponds to the imaginary part of the complex permeability
