Limitations
Introduction
Some limitations remain for this new application:
Geometry and domain
- Symmetries non supported.
- Periodicities non supported.
Mesh
- The mesh should not be too refined in order to take advantage of this new methodology without overloading the solver which needs to inverse a full matrix.
- Consequently, it is advised not to import the mesh from an external tool.
 Figure 1. On the left, a good mesh for the integral method. On the right, a good mesh for finite element method.
- The elements of a mesh must be of the same type (only tetrahedrons or hexahedrons, but do not mix both).
- No pyramids or prisms (the extrusive mesh is not recommended).
Physics
- Linear isotropic
- Isotropic analytic saturation
- Isotropic analytic saturation + knee adjustment
- Isotropic spline saturation
- Linear magnet described by the Br module
- Linear magnet described by cartesian vector Br
- Only magnetic non-conducting volume regions are available.
- No face regions, line regions and point regions.
- No non-meshed saddle coils.
- No non-meshed multi saddle coils.
- No non-meshed coils in open path.
Parameters / Quantities
- No sensors.
- No Import/Export context.
- In general, the use of import and export functionalities is not recommended.
Solving
- Solving of the linear system with GMRES only.
- Solving of the non-linear system with Newton-Raphson algorithm.
Post-processing
- No losses computation (iron losses & joule losses).
- Available quantities : torque, force, magnetic flux and energy.
- Only the isovalues and isolines of B and H are available.
- B and H can be displayed on 2D and 3D grids in the air.
