Introduction to meshing process
Definition
The meshing process consists of dividing the study domain into mesh elements.
The summit of a mesh element is called a node.
Mesh or elements are called:
- volume elements, for a volume domain
- surface elements, for a surface domain
- line elements, for a line domain
Meshing and finite elements
The meshing process is a key step in the finite element method. The finite element method calculates and gives an approximation of the state variables on each node of the mesh, (scalar or vector potentials, temperature,…) and of the fields which are derived from (magnetic field and induction, electric field, flux thermal density,…).
Mesh and results
The quality of the approximate solution depends on the mesh. Thus, the quality of the solution depends on:
- the number and the dimensions of the finite elements,
- the interpolation functions in each element, which can be 1st , 2nd order polynomial functions,
- the continuity conditions imposed on the sub-domain boundaries.
Mesh elements form
The different forms of the mesh elements are presented in the table below.
| Face mesh | Volume mesh | ||
| Triangle | Tetrahedron |  | |
| Pentahedron | |||
| Rectangle |  | Hexahedron |  |
| Pyramid | |||
Structure of a mesh element
In terms of the geometry, a volume element is characterized by its vertices, edges and faces.
Elements of 1st and 2nd order
Different types of finite elements are available to the user: these are called 1st order elements or 2nd order elements.
Specific information about these elements is presented in the following table.
| Type of element | Position of nodes | Interpolation function |
| 1st order | Vertices | Linear (1st order polynomial) |
| 2nd order | Vertices + middle of edges | Quadratic (2nd order polynomial) |
Field calculation: 1st and 2nd order approach
Using 1 st order elements: the potentials are approximated linearly and the fields derived from the potentials are constant.
Using 2 nd order elements: the potentials are approximated quadratically and the fields are approximated linearly.
| Element | Potentials | Field |
| 1st order | Linear approximation | Constant |
| 2nd order | Quadratic approximation | Linear approximation |
