Switch and Diode: definition (structure)
Definition
A switch and diode components are defined by:
- a name (and a comment)
- a model
- specific characteristics depending on the model
- a command
- two terminals
Name
The name permitting the identification of the component is given by the user when this is created by him.
A comment (optional) can be added to the name.
The name and the comment are displayed by default in the graphic zone close to the symbol.
Switch and Diode: description
Characteristic quantities, necessary for the description of the switch and diode components are presented in the table below.
| Components considered | Proposed models and their characteristics | |
| Switch Diode | Roff : blocked resistance Ron : resistance in conduction | |
| Diode | Exponential functions | Is : saturation current Rs : series resistance Ut : voltage of the temperature |
| Is : saturation current Rb : extrinsic resistance VF0 : bend tension | ||
Associated command signals
The switch need a signal to command them. The table below presents the different possibilities of commands.
| Proposed commands and their characteristics | ||
| At start | By formula | |
| By square signal | Pulse start End of pulse Period of signal | |
