Explanation of results (3D)
Current crossing a surface
If the surface of the S area is perpendicular to the current lines and the current density has the same value J at any point on this surface, the electric current crossing the surface is: I = J S
For a surface whose normal  is
randomly directed with respect to the current density vector, then
 is
The current flowing within an undetermined surface will be:
