Global quantities (electrical component) available in Magneto Static
Usual global quantities (Component)
The usual global quantities available for a computation on an electrical component in magneto static are presented in the table below.
| Usual global quantities (Electric component) in MS | Flux Name | Flux Unit | Application | |||
| 2D plane | 2D axi | 3D | ||||
| Coil conductor | Flux (magnitude) | FluxCoil | Wb |   |   |   |
Global quantities « advanced » (Component)
The global quantities (advanced used) available for a computation on an electrical component in magneto static are presented in the table below.
| Global quantities “advanced use” (Electric component) in MS | Name and formula |
| Electrical potential on the terminal of a circuit point CP | V(CP) |
| Difference of potential between two circuit points CP1 and CP2 | V(CP1) – V(CP2) |
