Post-processing quantities: translation motion)
Introduction
This paragraph deals with physical quantities computed for translating motion.
Kinematic variables
The list of kinematic variables used for solving and the names of the corresponding Flux parameters are given in the table below; in this table MS indicates the concerned mechanical set.
| Kinematic variable | Name | Unit |
| Linear position: y | LinPos(MS) | m |
| Linear speed:   | LinSpeed(MS) | m/s |
| Linear acceleration:   | LinAcc(MS) | m/s² |
Physical quantities
The list of physical quantities computed in the post-processing module and the names of the corresponding Flux parameters are given in the table below; in this table MS indicates the concerned mechanical set.
| Force | Name | Unit | Explanation |
| Electromagnetic force: F em | ForceElecMag(MS) | N | |
| Internal system | |||
| Friction force:   | ForceFrInt(MS) | N |   |
| Spring return force:   | ForceSpInt(MS) | N |   |
| Inertia force:   | ForceInInt(MS) | N |   |
| Resistant force*:   | ForceReInt(MS) | N |  or   |
| External system | |||
| Friction force:   | ForceFrExt(MS) | N |   |
| Spring return force:   | ForceSpExt(MS) | N |   |
| Inertia force:   | ForceInExt(MS) | N |   |
| Resistant force * :   | ForceReExt(MS) | N |  or   |
- either the sum of the friction force + the spring return force
- or the resistant force defined using a formula
Reminder of the solved mechanical equation
The solved mechanical equation for translating motion is:
where:
- m is the mass
 is the mass of the
               moving mechanical set (internal system) is the mass of the
 is the mass of the
               external load (external system) is the mass of the
 is the
               electromagnetic force is the
 is the resistant
               force is the resistant
               force
 is the resistant
               force acting on the moving mechanical set (internal system) is the resistant
 is the resistant
               force acting on the external load (external system) is the resistant
Important note
When there are symmetries and periodicities, the forces are computed for the entire device.
