Management and execution of command files
Management of command files
The command files are managed:
- either by Flux, in automatic manner (default files)
- or by the user
Automated management
Two files are automatically managed:
               the “Flux[XX]_log.py” : all commands performed by the user during a session are recorded in this file. This file is stored on the current working directory.
               the “Project_PyFlux_log.py”: all commands performed by the user during the beginning of the project up to the end of the project are recorded in this file. This file is stored with the save of the project at the following link : …\project.FLU\persistent\Jython_log
| Flux module | Current session file | Previous session file* |
| 2D | Flux2D_log.py | Flux2D_log_bak.py |
| 3D | Flux3D_log.py | Flux3D_log_bak.py |
| Skew | FluxSkewed_log.py | FluxSkewed_log_bak.py |
| 2D, 3D and Skew | Project_PyFlux_log.py |
* In order that the file Flux[XX]_log.py should not be reinitialized (rewritten) upon the opening of a new session, the file is renamed by Flux (*_bak.py).
User management
The user can manage command files by means of the Flux commands from the menu.
| Flux command | Function |
| New | creation / opening of a file |
| Interrupt | break of the sequence saving |
| Resume | resumption of the sequence saving |
| Close | end of the sequence saving / closing the file |
Note: It is impossible to open two command files at the same time for a Flux session.
Modes of running
There are two modes to run a command file. These two modes are presented in the table below.
| Mode | Description |
| direct | mode with graphic refreshment |
| silent | mode without graphic refreshment (faster execution) |
Run a command file
To run a command file, you can use one of the two following methods.
Method 1: from the supervisor (only batch mode):
- double-click on the file name
Method 2: from the Flux window (silent mode or direct mode):
- in the Project menu, point on Command file and click on Run a python file or Run a python file in silent mode
- in the dialog box, enter the file name
- in the python editor, open the file and execute it (direct mode)
All the PyFlux instructions from the command file are ran.
Warning: For a correct process of operations, it is necessary to run the command file in the appropriate context (expected by the command file).
