Main functionalities
Manage databases
The first step in this context is to choose a database. The actions for database management are presented in the table below:
| Command | Access | Function |
| Create a database |   | Create a database with a name and a saving location |
| Load a database |   | Load an existing database in the materials manager in order to manage its materials |
| Unload a database |   | Unload a database when there is no more need to manage its materials |
Manage materials
Once the database is chosen, it is then possible to manage its materials. The materials management actions are presented in the table below:
| Create a material |   | Create a new material |
| Delete a material |   | Delete an existing material |
| Modify a material |  or
                        double-click | Modify the data of a material |
| Copy/Paste a material | Drag&drop material | Copy/Paste a material into same or another database |
| Import a material |   | Import a python file comprised of the creation commands for the materials |
| Python export of a material |  | Export the python commands for materials creation into a python file |
Manage materials data
Once the material is created or opened, it is then possible to manage its general data and properties. The materials data management actions are presented in the table below:
| Associate general data to the material |   | Associate general data |
| Associate properties to the material | Access to the magnetic property:  | It is possible to associate magnetic, electric, dielectric and thermal properties to the material. |
| Access to the model choice:  | Associate an analytical or a numerical model to a property | |
| Copy or replace a property | Contextual menu: Copy and paste on the material or drag & drop | Copy a material property into another material (add or replace) |
General commands
The general management commands are presented in the table below:
| Save |   | Saves the databases which were modified |
| Exit |   | Leaves the application |
| Help | Help menu: Help | Opens the Flux html help containing the material manager help |
