Face: about
Faces
Faces can be built:
               with the aid of automatic construction algorithm (automatic identification and creation)
- by propagation from existing faces with the aid of a transformation
- by extrusion from existing lines with the aid of a transformation
Faces built by Flux PEEC
The faces built by Flux PEEC are included in planar surfaces. The types of faces are presented in the table below:
| Face of following type | is built … |
| automatic |
| structured |
Structured faces
The building of a structured face is shown in the figure below.
where :
- bottom line is the source
- upper line is the image
- side lines are connection elements
