Global post processing: about
Introduction
The global post processing allows obtaining a global result :
- on the full domain or on a part of the domain (choice of region)
- on mechanical set
- on component of circuit
How access to global quantities?
Usual local quantities are the quantities available for the postprocessing:
               of a curve in function of one or several parameters (time or I/O parameter of the solving scenario), accessible by the commands: 2D curve (I/O parameter) or 3D curve (2 I/O parameters)
               of a global computation for one fixed instance (parameters of the scenario are fixed), accessible by the commands: Computation on physical entities or Predefined computation
Usual quantities
A list of quantities called “usual” is automatically proposed for a global post processing.
Quantities are stored in 3 categories :
- Region
- Circuit
- Mechanical set
