Energies and powers (mechanical system)
Introduction
This section deals with the stored energy and the power dissipated in a mechanical system in motion.
Power: definition (reminder)
The instantaneous power developed by a force F (a torque G) is equal to the product of the values of the force (of the torque) and the instantaneous velocity.
             (translating motion)
 (rotating motion)
 (rotating motion)
Regarding exerted forces
Among the forces which are exerted upon the mechanical system, one can distinguish:
- the conservative forces, which derive from a potential energy (see the following section)
- the non conservative forces, which can be:- the forces of system interaction with an external operator, which can produce an increase or a decrease of the mechanical energy
- the forces caused by constraints (i.e. the forces of contact with another system, for example forces of friction if the object is moving in a fluid medium), which, by opposing the motion, yield a decrease (loss) of mechanical energy
Elastic potential energy: definition
The potential mechanical energy of a mechanical system is the energy that the system possesses by:
- its position (potential energy of the gravity)
- its shape (elastic potential energy*)
Example:
Let us consider a system consisting of a mass m subjected to the action of gravity and suspended from a spring of elastic constant k.
In this case, the system potential energy is equal to the sum:
- of a potential energy of gravity: mgx
- of a potential elastic energy: kx2 /2
Stored energy
In the cases we are interested in the mechanical energy stored as the potential elastic energy. This is expressed as:
             (translating
motion)
 (translating
motion)  (rotating
motion)
 (rotating
motion)
Dissipated power
The forces or torques that results in the dissipation of energy are the forces or torques yielded by the constraints (friction forces/torques).
 (rotating motion)
 (rotating motion)
